lloydern:I only get 15 different radiostations
it has been years since I used BeoPlayer without a BeoPort
However I am sure I got more than 15 stations !
There is the "trick" of adjusting the quality settings you are happy to live with
(I forget exactly where this is the configuration menu)
Just set the quality bit rate as low as possible, and then see how many radio stations appear
Good luck !
									    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
