Latest post 09-13-2010 10:00 AM by wortonmiller. 4 replies.
Page 1 of 1 (5 items)
  • 08-16-2010 11:40 AM
    Beosound 9000 aux input
    Hello all
    When I connect my MP3 player to the aux input of my 9000 I have to turn both it and the 9000 up to full volume (72 !!) to hear any sound at all. Is there anything I can do to fix this?
    Chris
  • 08-16-2010 2:42 PM In reply to
    Re: Beosound 9000 aux input
    I suspect you have a DIN - 3,5mm plug adapter that is wired for the wrong direction (i.e from the DIN to the plug). Therefore you are not getting the actual signal, just some crosstalk.
    -mika
  • 08-16-2010 3:16 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Agree. Just get a DIN to 4x cinch adapter, so you have inputs and outputs. Now you can find the AUX ins....
    Stefan
  • 08-17-2010 4:28 AM In reply to
    Thanks, I'm using two cables, a 3.5 to RCA then RCA to DIN. I'll check its connected OK or replace the two cables with one I know is OK.
    Chris
  • 09-13-2010 10:00 AM In reply to
    Sorry for late reply.
    I changed the cable for a known good one and it works just fine. thanks for the pointers. chris
