Latest post 09-06-2010 1:09 PM by Seanie_230. 4 replies.
Page 1 of 1 (5 items)
  • 09-04-2010 9:50 AM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    BV7 DSM Module Help
    Hello All
    Help needed.
    My build is 7.14 with all modules up to date apart from the DSM module.
    When i bought the tv the dealer did auto update and this did not update the DSM module, i mentioned about this as i need the module to have a higher level so i can use ML delay to fix the echo issue.
    The dealer in question said as far as he is concened its up to date and flashing it again would give the same results.
    Today i had another dealer try and update the software:
    Read software ok all modules showing up to date apart from the DSm which is hardware version 2.5, (only boxes ticked are dsm to update)
    We click select software to update and the start and get
    communication issue message from the service tool.
    Selecting the dsm module rather than auto update gives an error saying tv is not connected or powered off or needs a reboot.
    This is strange as it reads ok but will not write to the DSM.
    Help Please all you helpful experts.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 09-05-2010 5:54 AM In reply to
    • tompa
    • Top 500 Contributor
    • Joined on 06-30-2007
    • Sweden
    • Posts 94
    Re: BV7 DSM Module Help
    then the connection issue come did you try to unplug tv from mains >40sek ? and then try manual again?
    If so, probely in earlier updates the dsm have been miss to uppdate so the "build" is incompatible , What Sw.ver has DSM Now ?
    /Tompa
  • 09-05-2010 6:11 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Yeah the tv was powered off for a while and it reads perfectly.
    DSM DSP Sw is 4.19a and the software table shows as 4.19 wasbuild 548 but not 4.19a
    DSM FEP SW is 4.23a and that is not even in the table 4.22 was build 548
    Has anyone ever seen this before is it worth rolling back to an older build where all modules match and re-flashing to the newest version?
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 09-05-2010 6:51 AM In reply to
    • tompa
    • Sweden
    • Posts 94
    I think you have to downgrade sw (The hole Build) to build 551 (H8sw 7.05) and then do  upgrade to latest build 714
    /Tompa
  • 09-06-2010 1:09 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Funny enough the dealer went back to his shop and tried to update his BV7 and had the same error.
    Turns out it was the serial cable as via USB convertor it worked perfectly
    I now have AST menu and ML delay has been switched on and i have no echo with my link room.
    My DST module is now up to date with the rest of the build.
    One thing i did notice is that the Bluray said it needed a manual update but there was no update avail via teh internet.
    Oh well it works so i wont fix it
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
