Well most pre amps just have a switch to set it to either MM or MC. In that case you would set it to MM. Reading the following in the link you sent.
Lower gains (40 and 44 dB) are intended for moving magnet cartridges or
very high output moving coil cartridges (2.0 milliVolts or higher). These
would include the Benz MC20E2, Silver, Glider High Output and H2O.
I'd set it to 40 or 44dB. Just see which is the best out if the two.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
