        1st March February 2012
	    Latest post 07-23-2010 7:22 AM by  joeyboygolf. 10 replies.
								        07-20-2010 7:15 AM
									        Dmitry
								                - Joined on 05-17-2010
								                - Rostov-on-Don, Russia
								                - Posts 36
										    Beogram 5005/5500 LP- is the tonearm start position adjustable?
										    Hi, everyone!
Faced the following trouble: when starting the vinyls with the wide empty edge (when the lead-in groove is 2-3 mm from the edge), the head slips off the vinyl, and falls down!
Is the starting point adjustable? I'm afraid, if these tricks continue, that will kill the MMC2.
Many thanks!
Dmitry
									    Beomaster 5500, Beogram CD50, Beogram CD5500, Beogram 5005, Beogram 5500, Beolink 1000, Beo4, Beovox 3702
									        Dmitry
								                - Posts 36
										    Re: Beogram 5005/5500 LP- is the tonearm start position adjustable?
										    Found the Service Manual.
Is it the Pickup Parallelism, that can adjust it?
									        Dmitry
								                - Posts 36
										    Now I see there the Eccentric Disc "E", but cannot understand, where is it located- is it under the outer metal disc, covering the mechanism, or under the back panel, hiding the lid opening hooks?
									        joeyboygolf
								                - Joined on 04-16-2007
								                - Ely, Cambridgeshire, UK
								                - Posts 3,252
										    It is inside the deck under the outer metal disc!
I suggest that you take some time to study the service manual at length. One wrong move could be costly.
									        Dmitry
								                - Posts 36
										    OK- I see it on the picture.
There is an Eccentric disc (marked with "E"), and the directions are mentioned "IN" (counter-clockwise) and "OUT" (clockwise).
Will reach the Beogram tonight, and will check out alive.
Will report on the results.
Thank you very much!
									        Dmitry
								                - Posts 36
										    Could not find that eccentric, provided by picture in the Service Manual.
Could someone explain, where should I look?
Seems it is somewhere at the right- near the tonearm. Is it reachable if I remove the metal disc and the plastic round cover?
Thanks a lot in advance!
BR
Dmitry
									        joeyboygolf
								                - Posts 3,252
										    No, You won't find it unless you open the deck up. I get the impression that this could all end in tears. TAKE CARE
Remove the silver platter
Slide the carriage over to the centre until it stops
Locate and remove the two Phillips headed screws under the right hand side of the deck
Carefully lift the right hand side of the deck which will open rather like the trunk of a car with the hinge being on the left hand side
You can now see the eccentric E at the rear right under the arm sliding carriage
Good Luck
									        Dmitry
								                - Posts 36
										    People are still driving LADA in this country! So hope, that keeped our @$$e$ away from our hands!;-)
Thank a lot for the detailed advise: I've noted that ingenious "trunk" fixing at the bottom, when only received the Beogram. Will try that today and keep posted. Think, there is a little adjustment needed- there is a 2mm tonearm position gap available, that is quite enough.
									        Dmitry
								                - Posts 36
										    Dear Graham,
Thank you very much for the explanations!
Today I've opened the "trunk" easily (then it is necessary to move the tonearm back to the right side from the center to reach the Eccentric "E").
Then I turned the Eccentric 180 degrees, that moved the tonearm start position 2 mm inside (closer to the center of the disc).
Now the stylus catches the lead-in groove even at the nude-edged vynils.
Great!
        Page 1 of 1 (11 items)
