1st March February 2012
Latest post 07-13-2010 11:13 AM by vikinger. 7 replies.
07-13-2010 2:56 AM
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
Re: Table stand for remotes, a B&O product?
Hi, it's not made by B&O. It's been talked about here before, but I can't find the thread.
vikinger
- Joined on 04-16-2008
- Vestri Kirkjubyr, UK
- Posts 2,839
Sigmund:
eBay pictures are a bit indistinct, but this might be the same product on a Danish site.
Someone has, in the past, sold stainless steel versions of a stand on eBay. These were one-off seller manufactured versions (but looked quite stylish!)
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
Daniel
- Svinarp, Sweden
- Posts 1,284
Thanks Graham, I knew I had seen them on a Danish site, but couldn't remember wich.
Are you thinking about this?
vikinger
- Posts 2,839
Daniel:
Thanks Graham, I knew I had seen them on a Danish site, but couldn't remember which.
No, but that looks like another stylish holder!
The stands previously sold on eBay had a very heavy circular stainless steel base, and the general form was similar to the design spotted above by Sigmund.
Graham
stotty1111
- Joined on 12-16-2007
- UK / France - Nth Worcestershire/Finistere
- Posts 924
Hi all
I must admit I have one of these - it now works verrt well with a BL1000 however had probs originally the support kept coming adrift and no matter what type of adhesive used that continued until the relative cofg of the bracket was adjusted then the whole became stable it works and looks fine -if I can find the camera I'll put a couple of views up!
NB my unit will only work with a BL 1000
salut tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
vikinger:
These were home made affairs with a Beo 4 wall bracket stuck to a circular base - I always thought they were a bit amateurish to be honest.
Chris.
vikinger
- Posts 2,839
Medogsfat:
vikinger:
Chris.
Best avoided in that case! The Beo4 wall bracket itself is not particularly well made (assuming we are talking about the same plastic holder) with a risk that if you drop the Beo4 into it it might shear off the bottom plastic stop leaving your Beo4 accelerating floor-wards!
Graham
Page 1 of 1 (8 items)
