Hi rjpollina, and welcome to the forum.
Your dealer is correct about the code, as soon as you enter the last digit (5) then press the OK button, it should beep.
Perhaps the problem may not be the batteries, but not receiving the charge.
Try cleaning the little brass terminals on the handset and also on the charger with a cotton bud dipped in Isopropanol or something similar.
Andy T.
