Stan, can I give you a big hug? You've made my day!
I thought I had already tried that with no results but I tried again after reading
your last reply. It worked!! I've been able to set up the clock and use the
timer function as well! I had called the Bang & Olufsen store in Glasgow and I was
asked £100 for the inspection only
.... you know B&O...
Thanks everyone for the advice given.
Bruno
