Latest post 05-14-2010 3:42 PM by Daniel. 8 replies.
Page 1 of 1 (9 items)
  • 05-14-2010 5:54 AM
    TV stand unknown
    Quick question,
    For which TV set is the stand made for?
    Mounting holes can be set in two positions 71cm and 79 cm.
    It doesn't fit on a MX6000, that's what I know.
    Thanks guys!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 05-14-2010 5:58 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: TV stand unknown
    Possibly for an LX series then. They both use the same stands but use different top plates.
    CraigSmile
  • 05-14-2010 6:05 AM In reply to
    • Peter
    • Top 500 Contributor
    • Joined on 12-28-2009
    • Sweden
    • Posts 134
    yes, it looks like the one I have on my LS5500 so it should be the same like the LX i suppose.. the ones with speakers on the sides
    /Peter
  • 05-14-2010 9:16 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    It's similar but not identical to the stand for my LX 5500. The unfolded parts are on my stand opposite each others. On yours it looks like one of them ends before the other. I'll attach a photo of mine.
  • 05-14-2010 1:24 PM In reply to
    • Beowulf
    • Joined on 04-16-2007
    • Derbyshire
    • Posts 143
    Possibly an LX6000?
    Beowulf
  • 05-14-2010 1:36 PM In reply to
    Thanks guys!
    Again, what a wonderfull place to be hereSmile
    According to the dims (products) of the LX 5000 & 6000 this would be 78 & 86cm width (difference 8cm), so that would match my dims I measured!
  • 05-14-2010 3:19 PM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    You are welcome, I will take a closer look at My LX6000 in the bedroom and get back to you tomorrow.
    Kind regards
    Dave
    Beowulf
  • 05-14-2010 3:37 PM In reply to
    Thanks Dave, very kind of you!Yes -  thumbs up
  • 05-14-2010 3:42 PM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Leslie:
    Thanks guys!
    I believe LX5500 and LX6000 has the same width, both have a 28'' screen.
