Latest post 04-20-2010 8:48 AM by burantek. 8 replies.
Page 1 of 1 (9 items)
  • 04-20-2010 7:26 AM
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Beomaster 7000 & MCL2a
    Does anyone know if the MCL2A x-tra speaker kit can be used with a BM7000? I'm asking on behalf of someone else and am unsure of the BM's capabilities.
    Thanks,
    Steve
    If you think nobody cares, try missing a couple of payments.
  • 04-20-2010 7:50 AM In reply to
    Re: Beomaster 7000 & MCL2a
    No problem AFAIK. You are, of course, limited to the same volume setting in both rooms.
    Regards Graham
  • 04-20-2010 7:57 AM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    Thanks Graham,
    I sold the kit to a guy in Luxembourg who was told by his dealer that he needed the MCL2A and that's all. Having received it he asked me how to connect it to his BM as it doesn't have the correct MCL sockets and only the 7 pin din?
    He's not complaining to me but obviously dissappointed and has been told somewhere that he'll have to fork out another 200 Euros to get it working together!!
    I would look up the BM's user manual but despite paying for the membership renewal and it showing as gold on my forum postings, it only classes me as a bronze member on the main siteAngry
  • 04-20-2010 8:12 AM In reply to
    • erandlux
    • Not Ranked
    • Joined on 11-07-2008
    • Luxemburg
    • Posts 39
    I am the buyer of the kit.  Thanks for so rapid reaction.  My only question is Where on my BM 7000 do I connect the MC2La ?  On the line entry ?
    What kind of connector do I need to finich the 7 pin cable.
    Since this system was designed for BM 5500m 6500 and 7000, it should be possible to connect it without any probs ?
    Thanks a lot for your help
    Eric
  • 04-20-2010 8:18 AM In reply to
    Stonk, can you confirm which product we are talking about? Note that MCL2A, MCL2AV, MCL X-tra speaker kit and MCL X-tra active speaker kit are all different products!
    As far as I know all of them are supposed to connect to the Beomaster via an MCL cable - and in all of them(?) it is connected to a screw terminal strip inside the box, so there is no connector for it. So you need an MCL cable with one end open for the MCL box, and with two 3-pin speaker DINs on the other end for the Beomaster.
    The 7-pin DIN sounds like it is the connector for the IR transceiver (or a Beovision AUX, depending on the product).
    (on the membership issue, have you tried logging out & back in already?)
    -mika
  • 04-20-2010 8:20 AM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    Eric, if it's the same as a BM6500 on the back of your BM7-000 you should have two sets of passive speaker connections plus the powerlink sockets. Speaker 2 are where you connect the MCL cables. The connectors are in the kit.
    I have sent you an email.
    Steve
  • 04-20-2010 8:28 AM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    tournedos:
    Mika, it's THIS kit. MCL2a is part of it.
    I think thes confusion lies in which sockets to connect the mcl cable with it's three pin connectors to the back of his BM7000. Eric is looking at the 7pin din which is incorrect. I have managed to look at the setup manual of a BM6500 which clearly shows the MCL sockets as the 2nd passive speaker sockets - just as the BC9500 or BM4500. Sometime overlooked when the unit is already connected and you can't see the back of the unit properly.
  • 04-20-2010 8:33 AM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    tournedos:
    Ah that was it. Well doneBeer
  • 04-20-2010 8:48 AM In reply to
    Sounds like you guys pretty much have it!
    Cliff notes:
    Power everything off
    SPK2 -> 3 pin din -> MCL Cable -> labeled terminals
    Transceiver cable -> labeled terminals
    Connect the speakers
    Set the SPEAKER PROTECTION DIAL to match the wattage of the attached speakers (Go lower for VOL limiting)
    Power back up... have fun!
    This is pretty basic kit... really just an extension of SPK2. Should you have problems at this point, we'll need to walk thru OPT programming. The MCL2A should be in OPT2 -the factory default.
    • B&o bottle opener
