Latest post 04-11-2010 1:49 PM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 04-11-2010 12:52 AM
    • Bogey
    • Not Ranked
    • Joined on 04-11-2010
    • Posts 1
    Beogram TX2 Turntable
    Beogram TX2 Turntable with an MMC 3 cartridge was just given to me for free.
    A question. If I am getting noise from the pulley area of the turntable, whether I spin it by hand or let the motor run it (and by noise I mean a soft click like a card in bicycle spokes that can only be heard when the music is not playing....it can also be heard when music is going, but only if your ear is near the turntable). Any thoughts on this.
    Much thanks.
  • 04-11-2010 1:49 PM In reply to
    Re: Beogram TX2 Turntable
    I suggest you remove the aluminium platter, it just lifts off. You may then be able to see something interfering with a rotating part.
    Regards Graham
