Latest post 04-07-2010 10:32 AM by Louise Scheele. 2 replies.
Page 1 of 1 (3 items)
  • 04-05-2010 12:12 PM
    Beomaster 4500 mutes when programmed
    I have the following setup:
    Beomaster 4500 sw 2.1 two-way
    4500 cd player
    Beolink 7000
    2 BeoLabCX100
    Beovision 7-32, no speaker, linked to Beomaster 4500 via 1611
    BM and BV in Option 1
    Beo 4
    2 LC 2
    Link:
    MCL: 2 BLCX100
    Beolab 2000 via 1611
    Problem: When I use my BL7000 to program my Beomaster to turn on the radio or 4500 cd-player at a given time it turns on, but the "mute"-function activates immideatly.
    Why does my Beomaster 4500 mute automatically when programmed?
    Do you have an idea?
    Kind regards
    Louise
  • 04-05-2010 3:27 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Beomaster 4500 mutes when programmed
    Hello again!
    Your timer is already programmed - but has not been activated!
    - BM4500 has to be in standby mode
    - touching "Programm" on BM shows "Timer"  (surprisingly in green letters!)
    - touching "Timer" activates/disables an already programmed timer
    If timer is activated "TIMER" (in red letters) is shown on the display of your BM 4500
  • 04-07-2010 10:32 AM In reply to
    Lieber Vienna
    Thank you once again - that solved my problem. You are indeed a bottomless well of knowledge about my own contry's most famous AV-producers! I think Beoworld would experience a radical added value if you documentet all you knowledge and publicised it here. I am indeed very impressed, mein Herr!
    Vielen Dank.
    Kind Regards
    Louise
