Sorry should have noted before, its type 2913 (mid 80's)
I'm surprised to read it is only 30W amp, as the back of the unit says 170W!  It never had problem pushing the M75's.
1- I inherited the BM2000 about 10 years ago and I know i stupidly played it at lower volumes despite the deteriorated foams.  (it actually didn't sound bad as long as the bass wasn't driven to much) I know you're all probably cringing ; )  I did get lazy (didn't want to remove and buy new dust caps) and didn't insure the coils were centered when i was re-foaming
so it may already be too late.  do you suggest i remove the dust cap and inspect the coil for center, shim if necessary, then reglue the foam to the frame?
Does anyone know what a new driver would cost in US$?  the other woofer in the same unit shows signs of cracking in the paper cone, i might replace that one too if cost effective.
2- As stated, the tuner never worked well for me. would a good tv repair man be able to repair the tuner section as well as trouble shooting the Amp problem?
3- yes i tried different wires, different speakers, and i noticed while it will push some sound thru the CX's it wouldn't push much thru the M's.  I'm glad to hear your opinion on B&O shops. i was starting to feel i was being cheap, but a budget is a budget, right?  Do you recommend any e-shops in particular?  I'm in the states on the west coast and would like to avoid shipping long distance.  I am more interested in investing in the repair especially if i am part of it and learning.  I never much like to just hand things over and pay for things to be done for me, but i do know my limitations and the B&O stuff is too special to give up on!
4- the multi speaker set-up included the following:  from "speaker 1" outputs to a speaker switch with four outs I had the (A) M75's in the living room, (B) cheap RCA 1.5W 6-Ohm spkrs in kitchen, (C) Aiwa (9.3 Ohm on my multimeter) compact system speakers in the garage.  I think my problem arose when more than one pair was on at a time, lowering the impedance beyond spec. I was ignorant as to the importance of impedance values and how to calculate their values when grouped together (in this case in parallell)
I'm really excited to be getting all this help (thank you, thank you to all!) and to see where this goes.  A light at the end of the tunnel?  Definitely!
