I have bought a old Beogram 6002 in a second hand market (22 Euro !!!). A nice vintage turnable.
After cleaning, oiling and tuning everything (following the service manual that I have download on the net), it works fine.
The only problems I have are :
1) the lamps indicating the RPM 33 or 45 are not very bright : I have still to check the voltage
2) I don't see any stylus pressure adjusting part, except the counter balancing weight wich is to be place so that the arm is floating when the pressure is set to 0 gr. I think that there a part lost lost.
Could somebody send to me a picture or a drawing of this part, with, if possible, some dimensions, so that I could make a one by myself ?
(I could find a little balance to mark the scale).
Thank you very much
