Hi, I have the primary loudspeaker sockets muted in my BM5500.
All was OK untill I plugged in headphones. They worked fine, but after unplugging them, the speakers did not come up anymore. Changing to the other sockets help, so the amp is OK. Pressing the mute-button does not release it, nor do repluggin/unplugging the headphones.
So, should I go after the headphone plug or the mute relay or its circuitry to find the problem?
I think I've seen a discussion about something similar, but could not find the thread.
Thanks,
Pekka
