Latest post 02-22-2010 2:46 PM by riis. 4 replies.
Page 1 of 1 (5 items)
  • 02-22-2010 12:10 PM
    • riis
    • Top 500 Contributor
    • Joined on 05-01-2007
    • Denmark
    • Posts 152
    How to remove scratches on Beocenter 9300 lid
    The lid of the tape deck on my BC 9300 has got a few scratches. Not very much, but it would be nice if there was a way to remove them. What material are the lids made of? Do you think it is possible to make them go away by polishing? You can feel the scratches when you run a finger nail across them. Or should I try to find a donor lid?
    /riis
  • 02-22-2010 1:03 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: How to remove scratches on Beocenter 9300 lid
    Not possible I'm afraid. The lids are anodised aluminium & any attempt to remove the scratches will make the appearance 100 times worse & make you wish you had never started. The only solution is to order a new one from B&O or learn to live with it.
    Chris.
  • 02-22-2010 1:27 PM In reply to
    • riis
    • Denmark
    • Posts 152
    Medogsfat:
    Chris.
    I've been told that you have to order a full set of lids (3 pieces) Is it so or can you get the lids seperately?
    /riis
  • 02-22-2010 2:01 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    all 3 only from bno as may be slight difference in appearanc-e - last i heasrd was about £90 uk for the three
    salut
    tont
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 02-22-2010 2:46 PM In reply to
    • riis
    • Denmark
    • Posts 152
    stotty1111:
    salut
    tont
    £70 - I'm afraid I have to live with the scratches Sad
    /riis
