Kevin,
What you need to do is an Image backup which means everything on your new hard drive is 100% the same as the old.
I suggest you use a product that I use called Drive Image from R-Tools, it works very well and you can even open the backup image up on another machine as a virtual drive.
You can download it from HERE
Keith..
