I have recently purchased a beogram 5005.  All the controls of the turntable seem to function well, except from the tonearm.  As soon as it lowers on the record, it starts to skate all the way towards the end of the record, and then returns to its initial position.  I know this is also associated with the servo motor, which seems to work continuously.
How can I fix this problem? Any suggestions?
Regards, Bruno Destickere
