hi,
i am looking into how to watch an hd source on a bv7-40 and distribute the same source in sd to a link room tv (not necessarily at the same time). my hd source is hdmi and i have found a variety of ways to have a hd and sd signal in parallel from the same source. i am now looking at precisely how this connects to the bv7-40.
the user reference manual states that it is possible to connect an hd and sd signal from the same source only to the av2 or av3 sockets. i find this curious and i am looking for more information.
i notive that av2 and av3 contain both a scart connection and composite hd (y pb pr) + spdif connections grouped together. is the bv7 somehow wired internally to manage these parallel sources or could i have my hd signal connected to a hdmi port and then assigned to av2 or av3 ?
and what is the role of the spdif precisely. if i transmit only digital audio will the bv7 be able to distribute it to link rooms with the sd signal or do i need to have the audio coming through on the scart ?
thanks for any and all help,
scott
