Latest post 01-20-2010 3:34 PM by Medogsfat. 3 replies.
Page 1 of 1 (4 items)
  • 01-20-2010 7:38 AM
    Datalink on Beogram TX
    I have a Mk1 version of the TX Turntable, it was originally bought in the US and works fine through a voltage converter - the output connectors are two phono plugs - does anyone know if the datalink module is inside the unit and could be connected if I changed the lead to a 7 pin din or if it was actually not included as it's a cheaper BG6000?
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 01-20-2010 7:53 AM In reply to
    Re: Datalink on Beogram TX
    Quote from Beoworld data,
    BEOGRAM TX
    Manfactured: 1983 - 1985
    Designer: Jacob Jensen
    Colours: Grey,
    This was a re-badged Beogram 6002 but without the one way Datalink module.
    It was fitted with the excellent MMC3 cartridge and could be used with other makes of amplifier. It was replaced by the much less substantial TX2.
  • 01-20-2010 11:38 AM In reply to
    Pretty sure that is correct. You have to clean the record anyway! Smile The datalink in the 6002 was only one way which was an oddity. These two decks are very similar in many ways to the 4002 and are very under rated.
  • 01-20-2010 3:34 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Yes the info' on site is correct. I owned one for a while and it didn't support datalink. The RCA/phono plugs were factory fitted, probably to appeal to non-beosystem owners.
    Chris.
