Cheers Graham, I think I may be being just a tad picky, but hey..............why not?
I saw on another post you are repairing a couple of BC9000's, for selling I would think, do you do repair jobs if they are sent to you?
You may or may not remember the many posts that I have been in the past regarding BC9000's problems reading discs. My 9000 does this when first switched on but after persevering for about 10-15min it works fine, almost like it needs to heat up before it can read discs.
PM me if you think you can help
