Latest post 10-20-2010 5:52 PM by joeyboygolf. 6 replies.
Page 1 of 1 (7 items)
  • 10-19-2010 6:09 PM
    Pre-Amps with non-RIAA Beograms
    This is probably a common question, sorry I'm new to this forum, but what is the requirement / specification for a suitable pre-amp to connect non-RIAA Beograms to a standard, non B&O amp?  For example would a NAD Phono Preamp PP1 be suitable or do you need something more specialised?
    Thanks in advance for your help.
  • 10-19-2010 8:25 PM In reply to
    Re: Pre-Amps with non-RIAA Beograms
    I'm no expert  but I think any decent quality preamp will do.  In fact, I think you can have better sound with a separate preamp compared to the built in B&O one.  Considering separate preamps can go for thousands of dollars, the sky is the limit in terms of what you can spend.
  • 10-20-2010 3:12 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    The Nad PP1 is pretty good - I have one and think it sounds fine. I also have a ProJect Phono Box though which is especially fab.
    The pre-amp really does leave quite a big mark on the sound...
     Weekly top artists:
  • 10-20-2010 6:52 AM In reply to
    I've been using the NAD for a while with an old TX - I tried a cheaper one the other day and it did sound thin in comparision, so switched back to the NAD. It is quite sensitive to picking up noise from transformers etc but works great once you've got it in the right place.
    I guess so much depends on the cartridge and turntable you are using as well. It would be good to have some sort of guide to good pre-amps and which ones people recommend from experience. This would be useful given that all the recent stuff doesn't have a preamp built in and the huge premium that is being charged for B&O turntables with built in pre-amps.
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 10-20-2010 11:26 AM In reply to
    http://www.tnt-audio.com/ampli/t-preamp_e.html Read this, I've been using it for 5 years now, no problems no distortion, what comes in comes out, and you have the choice of 3 extra incoming connections. Run it with my BG 2404, Ipod, computer, flatscreen, to BS 3000
    Soren
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 10-20-2010 2:26 PM In reply to
    Thanks everyone for the advice.
    Anyone know a good source of convertors for DIN plugs to standard phono ones?
  • 10-20-2010 5:52 PM In reply to
    iainwood:
    At the bottom of the page!!..... www.soundsheavenly.co.uk
    Regards Graham
