Hi!
I got a Beogram CD 3300 for repair. It's otherwise working but the DIN plug was cutted so I need to replace it. I have the plug but I have no idea which wire is which! I read the Beotech page about the Datalink but there was a green wire that this BG doesn't have. So far I have figured out that the red and white wires are the left and right channels and the shield is the ground.
So there are still blue, black and yellow wires to identify.
If someone have the wiring diagram of the plug - I would be more than thankfull to have a look on it!
The other problem with this BG is a cosmetic one. On the front between the aluminium strip and the touch-panel there is the grey-coloured bar. The colour was somehow dried and loosed as by scratching with a nail the paint came off. I scratched the grey paint off and now the front-line is black. Is there any easy way to repaint it or somehow make it look at least more original than it is now?
Bang & Olufsen - The art of controlling sound, picture and light
