Latest post 01-04-2010 2:33 PM by frankmj. 15 replies.
Page 1 of 1 (16 items)
  • 01-04-2010 3:41 AM
    XML file for Sagem ITSD81 HD
    I've changed to Canal Digital and need the file - anybody got one?
    Thanks in advance
    /Frank
  • 01-04-2010 6:02 AM In reply to
    Re: XML file for Sagem ITSD81 HD
    I am quite sure that it is in CT3.23.
    But I look for when I come home again
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 01-04-2010 6:42 AM In reply to
    Yes it's there, but as a PUC source. I want it as a third party source.
    /Frank
  • 01-04-2010 7:21 AM In reply to
    Frank,
    Click HERE for a Canal Digital XML for direct control from the Beo5. Hard keys and digits are pre-assigned in this XML file
    Regards Keith....
  • 01-04-2010 7:27 AM In reply to
    Thanks a lot Keith!
    I will try it right away.
    Cheers
     Frank
  • 01-04-2010 7:48 AM In reply to
    I'm sorry Keith, but it doesn't work with my Sagem. None of the buttons work.
    The buttons text in the file doesn't match the remote buttons text for the ITSD81HD either.
    /Frank
  • 01-04-2010 7:57 AM In reply to
    Well, I guess the Canal Digital remote I created that file from is different from yours.
    If you have the IR timings or can find the Pronto codes on the web, then send them to me and I will create a file for you.
    Regards Keith....
  • 01-04-2010 8:06 AM In reply to
    Yes, it must be different. There's no Pronto codes i'm afraid, but maybe Weebyx can help?
    /Frank
  • 01-04-2010 8:22 AM In reply to
    Frank,
    If you can use a Lintronic box to capture the codes, then a XML file can be produced.
    Regards Keith....
  • 01-04-2010 8:30 AM In reply to
    I know Keith, Unfortunately I don't have a Lintronic box, and I think it's to expensive to buy for this one time job.
    /Frank
  • 01-04-2010 10:16 AM In reply to
    Hi Frank
    It is in CT3.23 -> ThirdParties -> PUC Sources
    You can download it here
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beocom 6000
    • A8 Earphones
  • 01-04-2010 10:35 AM In reply to
    The correct PUC filename for this box is: Sagem_STB_HD81svensk_V01.00a.dec
    Keith can you create the XML from the DEC files?
  • 01-04-2010 10:43 AM In reply to
    guffas:
    I can create a Beo5 XML file from any PUC DEC file...
    Regards Keith....
  • 01-04-2010 2:11 PM In reply to
    Tillquist:
    Hi Frank
    It's the PUC file, I need it as a direct third party file, so I can control the box directly, not via the PUC.
    /Frank
  • 01-04-2010 2:19 PM In reply to
    Yes, it is
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beocom 6000
    • A8 Earphones
  • 01-04-2010 2:33 PM In reply to
    Tillquist:
    Yes, it is
    What is it? I compared the file with the one in the CT 3.23 and they are exactly the same. For use with beo4/beo5 to operate the box via PUC. Not what I am looking for. The PUC software is very unstable, I have to reset the box (and TV) very often. Never any problem with direct control.
    /Frank
