Hi, Can anyone tell me how to set this thing up, just can't figure it out....?
I bought it in 2002 and then I had the S/W upgraded in 2003 when I bought a second one. Since 2004 they haven't been used.
Nowhere in the manuals does it tell you how to connect the phone antenna to the phone outlet wall socket. Or at least I cannot see it. I have the table base/phone plugged into the AC socket. But what do I do with the antenna? There is only a telephone line coming out of it, when I plug it into the wall socket I just get "not connected with base" (or similar). Do I need to connect AC power to the antenna also? The reason I ask is because I also have 2 x AC leads in the box and a number of double adapters which say power/line on them. Trouble is, I cannot see anywhere on the antenna where I can connect the power.
Hope that makes sense?
I spent a lot of money on booze, birds and fast cars.
The rest I just squandered.
George Best
