Latest post 11-02-2009 5:04 PM by Jandyt. 7 replies.
Page 1 of 1 (8 items)
  • 11-02-2009 2:51 PM
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Beo 4 phono
    Just picked up a spare Beo4 (DVD version) on ebay & cannot find "Phono" in the list. I've always been a BL1000 fan (hence my limited experience of this remote) but for controlling my Avant I definately need a Beo4 and I'd like to also use it with my BS5500. I've a feeling the previous owner has deleted this from the list so how do I retrieve it?
    TIASmile
    Chris.
  • 11-02-2009 3:01 PM In reply to
    Re: Beo 4 phono
    Chris,
    I assume you mean that PHONO is not available when you cycle thru LIST, rather than being not available to ADD?
    Try this:
    1.) <press> LIST+STANDBY
    2.) <press> either UP or DOWN until you see ADD?
    3.) <press> GO
    4.) <press> either UP or DOWN until you see PHONO
    5.) <press> GO
    6.) <press> EXIT
    Now, confirm that PHONO is available when cycling thru LIST.
    • B&o bottle opener
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Re: Beo 4 phono
    Press [LIST] and [RED DOT] in the same time.
    Display reads [ADD?]
    Press [GO]
    Scroll with [ARROW UP]
    Here someone has to confirm. I believe [N.RADIO] is the same code as [PHONO]
    Press [GO]
  • 11-02-2009 3:10 PM In reply to
    Re: Beo 4 phono
    Daniel:
    AH! Good call/catch Daniel...
    Chris, if your remote is new enough, you won't find PHONO! I believe Daniel is correct: N.RADIO Yes -  thumbs up
    • B&o bottle opener
  • 11-02-2009 3:22 PM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Re: Beo 4 phono
    burantek:
    He he. You were faster, but I was correcter...  Wink
    Actually, I took my Beo4 in order to find out how to add [PHONO] as it was easier than finding the instructions. After one round in the list menu I had not found [PHONO]. That's when I remembered that [PHONO] was changed.
  • 11-02-2009 3:28 PM In reply to
    • Medogsfat
    • Posts 4,045
    Re: Beo 4 phono
    DOH Embarrassed
    I totally forgot about N.Radio being the "new" phono. Thanks for confirming my global embarrassment guysBig Smile
    In my defence though I have another DVD version which DOES have phono in the add > list options.
    Chris.
  • 11-02-2009 3:32 PM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Re: Beo 4 phono
    Medogsfat:
    DOH Embarrassed
    It's OK, we will not tell anybody. It will be our little secret. The others are occupied with the prize draw. Whistle
  • 11-02-2009 5:04 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beo 4 phono
    Medogsfat:
    DOH Embarrassed
    Chris.
    Numpty! Wink
    Poor me, never win owt!
