It´s not possible with MX7000 to get the puc list out of the menu, you have to se on the chip in stb controller module or if the technican
that insert it, have label it on the backside of tv , then you have the table version i can help you to see if the box you want to use is
supported(or you check with you nerrest b&o dealer)
Regards
Tomas
