1st March February 2012
Latest post 06-19-2007 12:43 PM by The Plumber. 20 replies.
06-18-2007 6:42 AM
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
It's only a beta version, but it appears to work...  When you get a Personal Message, you should now be able to tell by a little number in brackets by the word "Inbox" at the top of your screen. The number obviously corresponds with the number of messages waiting for you! Thanks to Van for finding and implementing this! Lee
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: New Feature on BeoWorld!
Very good! Made me check the inbox today!
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Much better! Thanks Van Chris.
Tom
- Joined on 04-16-2007
- Luxembourg
- Posts 3,175
that sure was a good idea! beoworld keeps getting better and better!
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Nice one! Cheers Van Andy T.
jonnyb
- Joined on 04-06-2007
- London, UK
- Posts 123
I'd forgotten all about PMs. Looks like I've had one there since April that I haven't even looked at. Oops!
Kevin
- Joined on 02-15-2007
- Moderator
- Posts 1,256
excellent makes life a lot easier Thanks Van
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
I have noted this new feature and I have (7) in the brackets, however I have read all the e-mail's in my inbox, but not deleted them. Does the number in brackets really mean un-opened e-mail's or e-mail's sent to you and still in your Inbox ?
The Plumber
- Plymouth UK
- Posts 669
I have 3 in brackets but no unread PMs. Very annoying as I'm on pocket Pc at the moment due to my laptop charger burning out and I've just spent 10mins opening and closing the email button to find the new email, before I gave up and found this thread.
Never Mind The Ball-Cocks
www.markmossplumbing.co.uk
A labourer uses his hands A tradesman uses his hands and his head A craftsman uses his hands, his head and his heart
9 LEE
- Moderator - UK
- Posts 5,223
So, it says Inbox(3) but you have no new PM's at all?
Anyone else with the same issues?
Lee
Alex
- Bath & Cardiff, UK
- Posts 2,990
Obviously it works in a completely different way to other forums, but I'd suggest people try logging out and back in again if they are having issues. May solve the problems, may not, but it worked on a forum I was working on where an unread posts counter wasn't working properly...
Weekly top artists:
Jandyt
- Posts 13,004
I had (1) then read it and it went. It probably will only start counting from when Van started the function. Read them all then the brackets will go,.......probably. Andy T.
Peter
- Posts 9,572
For those with numbers and no unread emails, check there are not some on further pages! They may be very old ones!
9 LEE
- Moderator - UK
- Posts 5,223
Peter:For those with numbers and no unread emails, check there are not some on further pages! They may be very old ones!
Good point!
van
- Joined on 10-19-2006
- Brighton, UK
- Posts 663
Hi all If the PM has been read then it should not appear in the bracket anymore. Could I suggest those that are experiencing problems please log out and then back in again. If you could then kindly let me know if you are still experiencing problems. V
mobeyone
- Joined on 03-27-2007
- UK
- Posts 955
Excellent!! A subtle but important feature!!
Keith Saunders
- Posts 3,810
Van, I had seven (7) in the brackets, so I did as you suggested and logged out and then logged in again and I still had seven. So, I went down my list of e-mail and read (opened) everyone of them again, the number in the brackets went down to one (1) So, I opened them all again and I still have one in the brackets.
9 LEE
- Moderator - UK
- Posts 5,223
How many pages of PM's do you have? If it's just the one, and all have been read - it's a glitch - but you may have another page of PM's lurking.. I made the same error myself! Lee
Keith Saunders
- Posts 3,810
I have 19 in my list on one page. However, I logged out and back in again, then open each of the 19 again and when I got to message 15 it went back to no brackets I cannot explain this situation
The Plumber
- Plymouth UK
- Posts 669
I have re-read all 5(arent I popular) emails and I now don't have any new emails shown, but I had already read these mails. I will delete all my previous PMs so the problem may have been a slight glitch. BTW the quick reply option doesn't work on Pocket PC (not a problem for me, just thought I'd point it out). Will hopefully get back on laptop tonight after I've been to PC World to get a charger and get ripped off.
Page 1 of 1 (21 items)
