1st March February 2012
09-26-2009 4:17 AM
Giang Nguyen
- Joined on 07-22-2009
- Hanoi
- Posts 28
How to adjust volume up and down for Beomaster 7000 without remote?
Hello, B&O lover!
I will receive a Beomaster 7000 in next some days, and it will be connected to my own Beogram CD6500. But unforlately, there is no remote, such as Beolink 1000, 5000, 7000 and Beo 4.
I have read Beomaster 7000's user manual, but I wondering how to adjust volume up & down without remote?
It is simple question, but excuse me, I have never used any kind of 5500,6500,7000 beomaster. So please help me to make clear this prolem.
Thank you.
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Re: How to adjust volume up and down for Beomaster 7000 without remote?
Unfortunately, absolutely no way. You will need to get a remote.
Giang Nguyen
- Hanoi
- Posts 28
Thank you so much for your reply.
Do I need a Beolink 7000?
Can Beolink 1000 solve this problem?
I am going to buy MCP 6500, will it can control Beomaster 7000?
beocool
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
Beolink 1000 and Beolink 7000 will work nicely with Beomaster 7000. I have no experience with a MCP 6500 but I think it will work...
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
MCP6500 will work but you can do 90% of jobs with Beolink 1000.
MCP = unreliable and eats batteries!
Beolink 7000 = unreliable and expensive.
Stick with Beolink 1000 is my advice!!
tournedos
- Finland
- Posts 5,808
Have to agree with Graham - a Beolink 1000 is the best for everyday use, closely challenged by a Beo4.
However, things like programming radio presets will be sooooo much easier with an MCP. And mine is still running on the first batteries I put into it in February last year... It will be a useful purchase, just don't pay too much for it.
Giang Nguyen
- Hanoi
- Posts 28
Thank you all for your advice.
I will find and buy Beolink 1000.
One more question, which speaker does the Beomaster 7000 drive best?
I have owned Beomaster 8000 to drive Beovox S80.2, and very satisfied. I am looking new pairs of speakers for my new Beomaster 7000. Any idea for the speaker ?
Tillquist
- Joined on 05-26-2007
- Denmark
- Posts 211
A pair of BeoLab Penta or BeoVox Penta is a good choose.
My Bang & Olufsen....
- BeoCenter 2 DAB/DVD mk.II
- BeoVision 7-40 DVD mk.III
- BeoLab Penta mk.III
- BeoLab 4000 icepower
- BeoLab 4000
- BeoLab 3500
- Beo 5
- Beo 4 mk.I & mk.III
- Beocom 6000
- A8 Earphones
Peter
- Joined on 02-12-2007
- Posts 9,572
The amplifier in the 7000 will drive any B&O speaker adequately. It also has Powerlink sockets so can use any modern Beolab as well. I disagree with Graham on this one though - the Beomaster 7000 with a Beolink 1000 is only operating at half its potential. You cannot program and you lose the two way communication. Yes, the Beolink 7000 is getting old and may well need repair, but it is the best remote ever made and gives you essentially the full system in another room. Yet to be bettered in my opinion.
Friedmett
- Joined on 04-28-2007
- Herning, Denmark
- Posts 840
I have 3 remotes for my Beosystem 6500.
1 Beo4 MKII
1 Beolink 1000. Printboard exchanged as it was DOA.
1 MCP 6500
On a day to day using the Beolink 1000 will cover the basics. I don't know how many time you actually set the radio channels in a place but its something I rarely do and you can change the frq. with the Beolink 1000 but not see the actual search. Do a search on Beoworld.
The MCP 6500 is to big to go be handheld so it needs a place where it can stand for longer period of times. As for batteries mine is still running on the ones I put in around 5 moths ago but I don't use it that much. Finding radio channels are simple with the MCP6500 and once stored you are better set with a Beolink 1000. One of the advantages is the sound, shift and av buttons being present.
The MCP was an afterthought as it was only the Beo4 that came with it. Its cheaper than a Beolink 7000 but I may get one. It also depends of the 2 way in my system. If there is no 2 way B&O then whats the point?
Bentleyman
- Joined on 12-29-2008
- Rochdale
- Posts 367
Hello all,
I have read this thread with interest as my audio set up is quite similar to those described :
I have a master 6500 with 2x CD's attatched (one cd7000 ; one cd6500) and a beocord7000. (I wanted to add a 3rd cd unit into the Tape 2 connection - but it dont work! - disappointing!) my 2nd cd unit (6500) is in the Phono socket and works perfect.
Remote controls I have an MCP6500 (mainly for display purposes) which I find perfectly reliable - if a little unpractical. Battery consumption is not really an issue if it's not used all the time. I do really fancy a Beolink 7000 but am concerned if it goes wrong it can longer be fixed..
For everyday use I have a Beolink 5000, a beolink 1000 and a Beo4 (MkI).
But - i have a question to add to this thread - re. muting a source (audio or avant tv) using the Beo4 - i cant do it. I often wish to mute my avant in order to listen to music without switching avant off.. with the beolink 5000 or 1000 it's easy (just hit mute button!) but with the Beo4 how do you mute your source and switch to another source? I end up having to turn down the sound one notch at a time using the beo4.....surely there gotta be a mute capability on the beo4...?
Regards,
Michael
Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2, RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500, BL 5000, Beo4 (x2), BL 1000 (x2)
tournedos
- Finland
- Posts 5,808
Bentleyman:
Yes, but well hidden - you press both volume up & volume down simultaneously
Bentleyman
- Rochdale
- Posts 367
tournedos:
Bentleyman:
Well!! Thanks for that mate! - i'd never have found that! VERY well hidden U are right!
Are you in the northern part of Finland may I ask..? I used to live in Overkalix, Norrbotten, Sweden - just about an hour's drive from the Finnish border...
Michael
BS 7000, BS 5500
tournedos
- Finland
- Posts 5,808
Bentleyman:
Quite the opposite actually: in Espoo, a 10 minute drive from Helsinki. I don't think I have been up that north in almost 20 years, except for some work related trips...
Giang Nguyen
- Hanoi
- Posts 28
Hello everybody again and I wanna say Thanks for your advice.
I have one question more.
I tend to connect Beogram CD 4500 to Beomaster 2400. But I found that Beogram CD4500 use datalink DIN 7-pin, while Beomaster 2400 has only DIN 5-pin.
How to connect them? or Is there any equipment or adaptor, that can connect them?
Peter
- Posts 9,572
Pins 6 and 7 should unscrew on the CD4500.
Giang Nguyen
- Hanoi
- Posts 28
Dear Peter,
Could you describe more details? How to unscrew it?
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Hi Giang. If you look at the end of the 'extra' pins, you will notice they have a small slot in them. You will need a very, very small screw-driver, the type used for spectacles. DON'T dump the pins! Selotape them to the end of the cable for future use.
Andy T.
Giang Nguyen
- Hanoi
- Posts 28
Dear Jandyt & Peter,
For sure, as following photo of 7pin DIN , I will unscrew pin 6 & pin 7. Is that right?
Giang Nguyen
- Hanoi
- Posts 28
Thank you all for your help.
It is easy to unscrew 2 outer pin. I use a small knife to unscrew it, but need a tiny tool to screw it back.
Page 1 of 1 (21 items)
