Latest post 09-30-2009 6:51 PM by Alkhasar. 2 replies.
Page 1 of 1 (3 items)
  • 09-30-2009 4:30 PM
    BeoLink Converter - Type 1614
    Hi
    why is there an extra powerlink source on the link Beolink Converter type 1614 ....?
    Beosound century Beocenter2 Beolab2 Beolab3 Beolab8000 Beolab6000Black Beolab4000 Beovision Avant 32 DVD RF MX7000ML MX4200ML MX1500 Beolink1000 Beo1 Beo4 Beo5 Beosound1 Beosound6 Beocom2 Beocom6000 Serene BeoPort A4 A8 A9 LC1 LC2 Kabinet 2168 Black line FORM1 Beotime Beotruck.
  • 09-30-2009 4:47 PM In reply to
    Re: BeoLink Converter - Type 1614
    Let's say you have a Beocenter 2500 and a BV7, connected by a Beolink converter.
    If all the speakers are connected to the BV7, it allow you to use local controls on the BC2500.
    The Powerlink cable tells the TV that you have started the hifi, and it also tells the TV if you change the volume on the hifi using local controls.
    p.
  • 09-30-2009 6:51 PM In reply to
    Hello from France
    I've read a lots threads and Phil seems very skilled on B&O devices and cabling ..please Help
    My DVD Avant is HS after 5  years : "Green CRT" du to a vice on Philips pro 32" CRT ??? :
    The bill : 1500 €...to maintain 7000€ from 2003
    1500 € is rhe price of a 50" plasma last Top Pana generation.
    I decided to maintain my 2 Beolab 8000 et 2x6000 et want to connect theses 4 speakers on a Pioneer new Icepower generation.
    I can't use de switch line (cinch) and connect the B&O speakers to the preamp, because I can't synchronize the 4 others speakers; with the BO
    Obliged to cut off the voltage "amp out" to charge the normal powerlink and reamplify the signal  internally in the 8000/6000
    Need  a "special BeO box" ( signal adaptator) ...again 1600€ ( 4x400€), which is more expansive than the new Pioneer 7x180W last generation !
    I can't accept again such a holdup. Do you know a solution to my situation?
    IF ye sor no, an answer will be highly appreciated.
    Thanks in advance
    Alan
