Latest post 10-12-2009 6:41 AM by yachadm. 4 replies.
Page 1 of 1 (5 items)
  • 10-02-2009 9:47 AM
    Piher trimpots
    Did B&O ever use those infamous black & white Piher trimpots?
    I just finished otherwise repairing a BM5500 which has these at the idle current settings, and I'd like to know if they have been replaced already. The solderings look original, unlike some other places...
    -mika
  • 10-02-2009 12:38 PM In reply to
    Re: Piher trimpots
    These ones?
    http://www.segor.de/bilder/0000bf54.jpg
    I've never seen them on a original B&O board...
    But why are they "infamous"?
  • 10-02-2009 12:55 PM In reply to
    Re: Piher trimpots
    Exactly those. So they have most probably been replaced already, I'll just let them be.
    Over here they don't have a reputation of being too reliable... but it might be just hearsay, they always worked for me.
    -mika
  • 10-02-2009 3:34 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Piher trimpots
    I have seen some. Beomaster 5500/6500 springs to mind but I've also seen them in TV's.
    Though they were always for standard tiny Philips screwdrivers, rather than hex.
    I've probably replaced a few but never had much trouble with this type particularly and wouldn't worry
    about mounting new ones of the same type.
  • 10-12-2009 6:41 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: Piher trimpots
    Mika,
    I've been using these for years with no problems. I use them specifically when adjustment must be made through a hole in the PCB from the foil side (ie - no access to the component side). All my restorations of the BG 4002, 4004, 6000 have been with these.
    If there is access from the component side, then I use the Bourns 3352E Cermet trimpots.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
