Latest post 09-14-2009 6:39 AM by pentalex. 3 replies.
Page 1 of 1 (4 items)
  • 09-12-2009 10:03 PM
    • KalK
    • Not Ranked
    • Joined on 09-10-2009
    • Posts 27
    Beomaster WIth Preamp output
    Hi All,
    I was wondering if someone can tell me which beomaster has preamp output. Second question is, which beomaster is the most reliable, meaning which one gets to repair shop the least or hardly seen by a tech.
    Cheers
    Beonewbie
  • 09-12-2009 10:29 PM In reply to
    Re: Beomaster WIth Preamp output
    Beomaster 5000
    It is the Master Control Panel that seems to have the most reliability issues and for which there are now no spares, but depending upon what you want that may not be an issue
    Also see the terminal 5000
    Beosystem 5000
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 09-13-2009 3:50 AM In reply to
    The 5500 does as well but not the outputs marked pre-amp!! These will work but actually go through the power amp and then a very big resistor! The sockets joined by the metal hoops are proper pre-amp outputs - I loop these through my headphone amplifier. Disonnecting them will stop the power amplifier working unless you can loop back. The fault the 5500 has is the mute relay which affects Speaker 1 - usually one channel. A cheap fix. The 5500 has the advantage of lots of connections, like the 5000, but also works with a Beolink 1000/Beo4/Beo5 etc which the 5000 will not.
  • 09-14-2009 6:39 AM In reply to
    The Beomaster 4500/3500 is also very reliable. You only have to check if the touchpanel is good connected.
    Every beomaster/center/sound has a pre-amplifier output. The powerlinkconnection is pre-amp. I connected for a while my Beomaster with Rotel amplifiers. Making the cable is very simple. 5 pin din to 2 cinch.
