I would add that I yesterday took away the front frame from my BeoVision 5 to clean it.
I started the BV5 first today so the picture was gone, I guess it does make the error but I'm not sure.
Could this be why I now have a black screen?
Grateful for any helpful answers.
Problem solved, there was no wrong I just turned off the mains
Switch to the PDP when I had removed the front frame of my BV5 to
clean it behind the frame. The switch is hidden behind the front frame and
when you remove the front, you can turn off the power only to the screen (PDP)
of mistakes, I must have turned off the PDP.
Next time I know
Regards
Jan
