Hi to all,
as you can see, i'm new to this. Great forums!
I recently bought a Beomaster 1900-2. Sometime dreams come true after a long, long time
But, i got a little issue with my new treasure. Maybe someone can give a hint, what may cause this:
After some time the balance indicatior dims its light. If you switch off and wait a little it will get get to normal brightness. Only the balance indicator is affected, all other lights are working perfectly. The time to dim varies and sometimes even nothing happens. I Got the impression, but i'm not really sure, this depends on the choosen fm-preset.
Anyone got an idea? Should I change the bulbs? What can cause this behaviour?
Thanks in advance for any help ....
Carsten.
