stefan:
Thanks for the info, Quim. I assume you have the BV7-40 MKIII..(?). I have (had) the same problem with my Tvix.
If you can deactivate the TV tuner, source "TV" should appear in the connections menu as source...(?). this is what the MKIV does. Can you confirm this?
Is it also possible to deactivate the DVB tuner in 6.11?
With Gefen expander you have 7 (seven!?) HDMI sockets......
Does anybody know anything about other improvements/changes?
Stefan
You are welcome, Stefan.
Yes, I have the Mk3, and the white flashes were even worse with the SW 5.08 with the Tvix at 24 Hz.
Yes, source TV appears in the menu.
Yes, is possible to deactivate the DVB tuner.
Yes, with Gefen HDMI Expander you will have 7 HDMI, but I think this is for the Mk4, to have 5 HDMI instead of 2. Gefen must be connected to C HDMI port.
Another improvements:
- Compatibility for Beomaster 5 in Beovision 9
- BS9000 clock gains time when BV is on standby.
Other minor issues that I should have to translate from spanish but they are too much technical for me, sorry.
