hello martin,
thank you for your quick answer!
if there is not record on the deck, the funktions are ok, first 33 than 45 at the center carriage get back
to home position.
if there is a record on the deck, the carriage goes to the beginn position of record - the pickup goes down
but the carriage continue goes to the center. - the carriage transport didn`t stop
quickly push the lift botton, and the pickup goes up and the carriage stops.
push on the lift botton, carriage goes ahead and pickup goes down.
if push LIFT the carriage stopps, then you can push START, the carriage goes to center and home position, also you can push STOP, carriage
goes directly to home position.
when carriage is stoppt all funktions are ok ( << >> / < > slow-quick transport, start/stop) Lift up - pickup goes up are ok
- only Lift down V - pickup goes down and carriage goes to the center
i hope these are good answers for your questions
greetings bernd
