Latest post 06-25-2009 1:44 PM by burantek. 2 replies.
Page 1 of 1 (3 items)
  • 06-25-2009 1:24 PM
    • Chris
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Bredene near Ostend-Belgium
    • Posts 143
    A story about a Beotalk 1200, buyed second hand...
    <!-- @page { margin: 2cm } P { margin-bottom: 0.21cm } -->
    Hi all,
    I got lucky and had the change to buy a second hand, very well conditioned Beotalk 1200.
    There were some faults on the machine, at first the cable between the set and the splitter was a cross-over cable, so the unit would not power-up. After changing this to a straight type cable, the unit powers-up.
    Well done I said.
    Next I connected the unit to the land line, and made a call to it. All went well, till I tried to listen to it. When I pushed the news or listening button, the unit just played the first 2-3 seconds and then it switched off completely, with a immediate switch-on again. I immediatly suspected the mains adaptor to be faulty, and my decision was right. It was a 7,5 Volts type, normally used on a Beocom 6000.
    I put the Beotalk on a laboratory supply and moved after several testing and calls, the power slowly up to 12 volts, what seems to be the best voltage for a satisfying working condition at listening and max. Volume.
    I had luckely in my garbage somewhere Whistle a spare 12 volts adapter for the unit.
    My conclusion is:
    I was lucky to have the technical luggage, to fix the Beotalk, but I have no technical details how much voltage the original mains adapter is. But I suspect it must be between 9 volts and 12 volts with around 500mA?
    Anyway the unit is working now perfectly and I am a satisfied buyer, the only thing I miss is a wallbracket.
    My lesson: You will have to be very carefull in buying second hand equipment
    Yes, I kown my spelling is horrible… Huh?
  • 06-25-2009 1:31 PM In reply to
    Re: A story about a Beotalk 1200, buyed second hand...
    Chris:
    My conclusion is:
    I have purchased a 'New' Beotalk 1200 (i.e. boxed and not used) and I am still trying to sort out the splitter wiring etc.
    The mains adapter says 9V 300mA 2.7VA
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 06-25-2009 1:44 PM In reply to
    vikinguk:
    Take a look here
    The 1100 and 1200 are identical (I have both) w/ regards to the tridapter and the respective pinouts.
    You can place it anywhere you wish and cut your RJ11 to suit.
    • B&o bottle opener
