Would anyone know if a pair of s25's would fit on a pair of speaker stands for s30's ?
Cheers
Jim
Does the S25 have bolt holes for the stands? I am not sure that it does. I would also suggest that the S25 needs really to be either shelf or wall mounted to boost the bass.
Your right about the bolt holes and cheers for the advice.
