I get confused with the configuration of "AudioMaster" on the BS5. I think it is a complicating term.
Simply put, the BS5 (head unit - not just the BM5) can act like a BS9000 or a BeoPort.
I use mine as a B&O audiomaster but not an "AudioMaster". There is no other music playing machine involved other than a BV7-40 (which is the Master/VideoMaster). The BV7 display shows N.Music and N.Radio. No track info is displayed (although this forum indicates more detail displays are in progress in terms of software updates). The BS5 displays nothing of the videomaster info.
I am not sure what a BV7 and a BS9000 combined with a BS5 would display. however, I would bet it still shows N.Music/N.Radio.
I did until recently have a DVI cable from my BM5 to BV7. However, in "PC" mode but WITH a BS5, this did not work well. Without the BS5, I'm guessing it will be the same as a BM1.
10%
