Latest post 05-17-2009 3:25 PM by insaneWHISTLER. 7 replies.
Page 1 of 1 (8 items)
  • 05-17-2009 9:52 AM
    cross compatibility
    hi guys. I am wondering which B & O CD players are compatible with the Beogram3300 system. My dad has a Beogram CD3300 that has finally bit the dust and would like to replace it. I have looked everywhere but have been struggling to find another. Another option may be to repair it - he suspects dry joints. Is it worth a repair? If so any recommendations as to who could repair it? (Hertfordshire/London area) Or should we get another compatible player?
    Your help would be MOST appreciated. Thanks
  • 05-17-2009 2:19 PM In reply to
    Re: cross compatibility
    ok, can anybody please tell me how many PINS  are on the Beogram cd7000 's DIN connector??? I have seen one and think it might be compatible with the Beomaster 3300 amp/tuner
  • 05-17-2009 2:22 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    7 - the outer two are used for communication between components (datalink).
  • 05-17-2009 2:24 PM In reply to
    so theres 7 on the 3300 aux/tuner. this should work right?
  • 05-17-2009 2:30 PM In reply to
    • Puncher
    • Posts 9,588
    insaneWHISTLER:
    Yup!
  • 05-17-2009 2:43 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Every Beo CD player should be fine. They all have a 7 pin DIN plug and can be controled via your BM3300 with BL1000 or Beo4.
    CD3300,3500, 4500, 5500, 6500, 7000.
    Hope this helps.
    Stefan
  • 05-17-2009 2:52 PM In reply to
    What are the symptoms of the CD3300? I'd get this repaired - Try Tim jarman at www.beocentral.com - he lives in your area and can be contacted via the Beocentral site. The 3300 system is of a certain design and the other players will not match as well from a style point of view. The CD3500 would be the closest.
  • 05-17-2009 3:25 PM In reply to
    Thanks guys for the info. Just got a Beo CD7000 off ebay and am going to get the 3300 CD repaired with Tim at some point. thanks again
