Latest post 05-24-2009 1:42 AM by Quim43. 4 replies.
Page 1 of 1 (5 items)
  • 05-23-2009 8:58 AM
    • Scud
    • Not Ranked
    • Joined on 11-12-2008
    • Australia
    • Posts 16
    BeoVox 1 Setup
    Hi there;
    hope you are all well.
    Just wondering, in regards to a BeoVox 1 setup, i'm thinking of installing outside. If i connect using the powerlink socket on my BS9000, will i be able to skip, pause, change cd etc etc from the remote outside, or will i only be able to control volume and whether the sound is on and off. I'm a bit confused as to how all the connections happen. Also what is the external amplification box with the BeoVox 1 for?
  • 05-23-2009 6:49 PM In reply to
    • Scud
    • Not Ranked
    • Australia
    • Posts 16
    Re: BeoVox 1 Setup
    any ideas?
  • 05-23-2009 7:14 PM In reply to
    • petermc
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Shepparton, Australia
    • Posts 87
    Re: BeoVox 1 Setup
    To gain full and seperate control of the outside speakers you'll need a Beolink Passive which is basically an amplifier with a IR sensor.
    You need to connect the Passive via Masterlink to your BS9000. You then connect the speakers to the passive. You'll gain full control of the BS9000 plus you can then operate the volume/tone separate to the main system.
    It works well; I have 2 passives - one for the bathroom and one for the outside speakers. The passives are located in the roof with the IR sensors the only things visible.
    Where in Australia are you located.
    Peter
  • 05-23-2009 9:55 PM In reply to
    • Scud
    • Not Ranked
    • Australia
    • Posts 16
    Re: BeoVox 1 Setup
    Hrm, what if my BS9000 is connected via masterlink to my BV7-40. How would i then connect the beovox via masterlink? Theres only one masterlink port?
  • 05-24-2009 1:42 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: BeoVox 1 Setup
    Scud:
    Hi
    You need a Masterlink Junction Box or, if you are good at soldering, do the job as I did.
    Regards
    Quim
