Latest post 06-08-2009 2:01 PM by Seanie_230. 7 replies.
Page 1 of 1 (8 items)
  • 05-22-2009 6:12 AM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Format 0
    Hello All
    When i press Format 0 to activate my DVI-D output on my BV7 MK3 it works perfectly when when i press it again it does not always work and i have to turn the TV off and on again.
    Has anyone had this problem.
    I have looked in the Cinema Timings Menu and that all seems ok?
    Also can i add a external IR for when in Cinema mode as the signal gets a little blocked when my screen drops in front of the TV.
    Also i have tried to turn cinema mode off with the screen out of the way?
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 05-22-2009 6:39 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: Format 0
    hi just spoke to a beoliving dealer
    i have been told once you press format 0 to come out of cinema mode you have to wait 50 seconds b4 the screen comes back on.
    can anyone confirm this?
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 05-22-2009 7:58 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: Format 0
    Update!!!
    Hello.
    I went home at lunch and format 0 is used to toggle between display and DVI-D connection.
    I can get in and out of Cinema Mode with TV, DTV, On Board DVD.
    When i attempt to do this with PS3 or SKYHD connected via HDMI i can get into Cinema mode but it does not come back out.
    Another Software Bug Found.
    Is anyone able to test this on their BV7 MK3 and see if they get the same????
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 05-23-2009 8:45 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Format 0
    NO problem here. I have different HDMI sources connected to my BV7-40 MKIII sw 5.02, and everything works fine with cinema mode.
    Stefan
    PS:Cinema mode can be enabled after 90 seconds (default setting?) again, because the screen has to move up completely and the projector has to cool down, befor it will be activated again. You can adjust these settings in the cinema timings....
  • 05-23-2009 11:16 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: Format 0
    hi there thanks for the reply all my cinema timings are set to Zero
    strange thing is it comes out of dvd tv or dtv straight away but any sources connected via HDMI do not???
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 05-26-2009 12:52 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: Format 0
    Hi there
    just tried it again
    PS3 connected via HDMI format 0 and it goes into Cinema Mode and format 0 again and it does not come out of cinema mode
    sky connected via hdmi and toggle into cinema mode works but toggle out does not.
    call to B&o technical from a dealer results in a refused conversation because the dealer is not a Beoliving dealer.
    Thanks Bang & Olufsen
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 05-26-2009 4:37 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: Format 0
    i have software 5.08a as i had many problems with the sync issues with sky hd, it seems my tv suffers from failures.
    what do you all reccomend as technical wont discuss it?
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 06-08-2009 2:01 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: Format 0
    Resolved:
    Everything needs to be in the correct order
    PJ needs to be switched off after tv goes back to tv mode or tv will not go back
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
