Latest post 06-07-2007 12:10 PM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 06-07-2007 7:50 AM
    • jgn
    • Not Ranked
    • Joined on 04-17-2007
    • Dublin
    • Posts 6
    Beovision 6-22 Lip Sync
    When I use my Beovision 6-22 with an NTL (Pace cheapie box) STB, I am getting a lip sync problem. The Beovision works fine with an analogue signal.
    While I suspect the NTL box is the cause, I have another Avant that is using a similar NTL box without any issues.
    Filed under:
  • 06-07-2007 12:10 PM In reply to
    Re: Beovision 6-22 Lip Sync
    Quite a common problem and certainly nothing to do with the Beovision 6-22
    This tends to happen for one of the following reasons:-
    1) The Pace STB has a fault or needs a software update
    2) The aerial signal is below 60% which would allow you to still have a reasonable analogue picture, but is likely to provide picture and sound mismatch on digital -- unlikely if you are using the same aerial for your AVANT which you say is fine.
    I think the best first action would be to use the STB which is working on your AVANT and put it on the BeoVision 6-22 and if it works without problems, then you know you have a problem with the Pace STB
    Regards Keith....
