Latest post 06-09-2007 2:37 PM by Medogsfat. 8 replies.
Page 1 of 1 (9 items)
  • 06-05-2007 3:43 PM
    Buttons on my Ouverture
    Hi to the techies Smile
    I don't dare post in here to give advice just incase I was the cause of breaking some of your B&O, so I'll stick to the questions for now.
    This isn't a major issue because I have a Beo4 of course, but I've noticed the volume UP button on my Ouverture has almost had it. I do have to push it quite hard for it to recieve my input. I guess this has just happened because its been used quite a bit. Is there any conveniant way of fixing this, or is not worth the hassle considering I use my Beo4 usually anyway?
    Thanks guys.
  • 06-06-2007 3:05 AM In reply to
    Re: Buttons on my Ouverture
    I've never seen a problem with the keyboard but from the service manual it looks similar to the type used in beolink 1000 or beo4 so I could believe it could wear out with much use.
    Should not be very expensive to replace. Part number is 7500270
    The front of the ouverture is not difficult to take apart.
    Regards Graham
  • 06-06-2007 7:55 AM In reply to
    Oh great!
    I'll give the part number to my dealer, correct?
    Then a simple enough job to do myself? I'll look at the service manuals.
    Thank you Graham.
  • 06-06-2007 5:51 PM In reply to
    Providing your dealer is willing to supply!
    Regards Graham
  • 06-07-2007 4:54 AM In reply to
    Oh! Why wouldn't he be?
  • 06-07-2007 6:10 AM In reply to
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    Oh they'll order it with a "when do you intend to bring it in to our service center sir?"Wink
  • 06-08-2007 10:24 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    joeyboygolf:
    Do you mean the MK1 & 2 beolink 1000's Graham with the celluloid membranes with black spots on which disintegrate?
    Chris.
  • 06-09-2007 10:08 AM In reply to
    From the service manual and from what I remember of the one I had apart a couple of years ago it is some sort of plastic sandwich construction. I would hope it's better than the BL1000 ones!
    Regards Graham
  • 06-09-2007 2:37 PM In reply to
    • Medogsfat
    • Posts 4,045
    Ah, like the membranes under the later BL1000's then. A bit of a shame as these are pretty much irrepairable.Sad
