Latest post 05-06-2009 3:47 PM by birgerbum. 5 replies.
Page 1 of 1 (6 items)
  • 05-05-2009 2:11 PM
    Beocentre 9500 CD Lens problem
    My beocentre 9500 cannot read CD / sometimes play with click sounds after servicing for 20 years. I sent it for B&O service and I was told that the CD lens is getting old and cannot be replaced coz' no parts are available now.
    Anyone know if this can be fixed apart from B&O service ? Many thanks.
    Filed under:
  • 05-05-2009 2:20 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: Beocentre 9500 CD Lens problem
    Not sure if the transport/laser is by Philips, but if it is, you can definitely get the parts here.
    Check first with the service manual which exact Philips unit it is, before you buy.
    http://www.ersatzteil.justone-schnepel.de/html/uebersichtsliste_lasereinheite.html
    Regards
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 05-05-2009 2:44 PM In reply to
    Mmmm! Not heard this one before. A geriatric laser lens!!!
    More likely to be c2103 on the servo board. Search the forum for "c2103" and you will find loads of info. Suggest you search the entire site.
    Regards Graham
  • 05-05-2009 5:39 PM In reply to
    Hi woobenedict
    You most replace the cap c2103 on the servoboard it,s located on the cd unit  it must be replaced with exactly the same type,and also change all the other cap's on the board the type here is not so critical
    regards
    jan
  • 05-06-2009 12:06 PM In reply to
    All,
    Thanks for information. I just call up the B&O service again today to understand the situation and know that they are using philip CD lens .. I am not an expertise on electronics .. maybe I try to fix it in some local servicing.
  • 05-06-2009 3:47 PM In reply to
    Hi woobenedict
    If you use a local service you must tell them that the c 2103 must be the same type and be sure that if its not a b&o service that the know how to handle b&o.
    regards
    jan
