Hi Nico,
I've also just purchased an MCL2P and MCL2AV without a cable, so I will be obtaining the plugs to make the cable from my local electronics store later this week.  Would you like me to get some spare plugs and make you a cable as well?
The plugs are "standard" DC power plugs, but there are MANY "standard" sizes (some of which vary in size by less than 1mm), so I will be taking the MCL2AV into the store to ensure that I get the exact replacements.
You can contact me via my sponsor link at the foot of this page if you need any assistance.
Best regards,
Steve.
									    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
