Latest post 04-22-2009 10:58 AM by rayfenwick. 7 replies.
Page 1 of 1 (8 items)
  • 03-25-2009 4:19 PM
    • Andy
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Melton Mowbray
    • Posts 128
    Beocenter 7700 switching off??
    Hi
    my beocenter has started just switching off after 3 seconds after any selection of ph TP or P1 - P6. Everything lights up then click switches off!! Has it died or can it be fixed??
    Many Thanks
    Andy
  • 03-25-2009 4:30 PM In reply to
    • henrik
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Stockholm, Sweden
    • Posts 299
    Re: Beocenter 7700 switching off??
    I had the same problem with mine, and it was caused by bad bias-trimpots. I had them replaced (and properly adjusted), and since then the unit works fine.
  • 03-25-2009 4:42 PM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    thanks
    but what are bad bias trimpots?? How easy is it to replace them??
    Thanks again
  • 03-25-2009 4:57 PM In reply to
    • henrik
    • Stockholm, Sweden
    • Posts 299
    I suppose it's really easy if you are used to soldering, but I'm not. :) I let a repair shop fix it for me, it didn't cost much.
  • 03-25-2009 5:00 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    I don't suppose your remote could be sending an 'Off' signal after three seconds?
    Just a thought. Try removing it from the room.
    Poor me, never win owt!
  • 03-25-2009 6:04 PM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    hi
    I have no remote but its a good suggestion if only it would be that simple but I fear not!!
  • 04-22-2009 6:43 AM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Hi
    have had a good look around and found these 3 wires the red, brown and orange wires are not connected to the inputs at the back around the tape 2 phono inputs. Could this be a reason for switching off?? Or is it a red herring??
    Andy
  • 04-22-2009 10:58 AM In reply to
    That cracked PCB might have something to do with it Erm
    Ok not directly, as that board is  only for TAPE2 and the pre-amp in/out, but as you have wires off and a cracked board just above where  all the output transistors are....it points to damage elsewhere.
    I've got 2 7700's in pieces at the moment, so if you need some spares PM me.
    Ray
    Я люблю Банг и Oлуфсен
