Latest post 04-17-2009 12:40 PM by Keith Saunders. 6 replies.
Page 1 of 1 (7 items)
  • 04-16-2009 3:55 PM
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Lintronic SW question
    I have some pronto codes for a Toshiba TV.  For example: 900A 006D 0000 0001 40BF 12ED
    When I enter this code into the Lintronic SW's "convert pronto" box, and press "convert", I get a pop-up that says "The command was decoded as 716 NEC-A (and the Lintronic code 716064191018237001000 displays in the "Decoded" box).  So far, so good.  However, at this point, it doesn't display the CodeForm generator screen so I cannot get the timings to give to the XML file generator.  What am I doing wrong?
    Thanks in advance,
    Stan
  • 04-16-2009 4:05 PM In reply to
    Re: Lintronic SW question
    Stan,
    If you are getting the Pronto codes from www.remotecentral.com beware that some are not always correct.
    Send me a full example of the Pronto code and I will check it.
    Regards Keith....
  • 04-16-2009 4:08 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    I think I have figured out a solution.  If I copy the Lintronic code to the Learned and Tested box with a command name, for example INPUT=716064191018237001000, then press "Draw All", it will display the CodeForm window.  Keith, can you confirm that this results in the correct waveform/timings?
    Thanks again,
    Stan
  • 04-16-2009 4:13 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    Keith,
    I did get the codes from www.remotecentral.com, but I found similar codes across a couple Toshiba examples.  Here are two examples, and they is the entire code.
    Power:  900A 006D 0000 0001 40BF 12ED
    Input:  900A 006D 0000 0001 40BF 14EB
    Thanks for the tip on the remote codes not always being correct.  Even worse, I also read on that same site that many/some Toshiba TVs can be harmed by receiving the wrong code.  Ultimately, if my testing continues successfully, I will have to invest in some type of IR capture device.
    Stan
  • 04-17-2009 2:46 AM In reply to
    Stan,
    When you paste a Pronto code to the "Textbox" in place of the Pronto code in the window and press the load in the Lintronic software, if the code is valid and decoded it will automatically display the timing.
    The start of the Pronto codes you have listed are NOT valid.
    Please inform me of the model number and product type for the Toshiba product you are trying to control ?
    Regards Keith....
  • 04-17-2009 12:14 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    It is a Toshiba 37HL17 LCD Television.
    Stan
  • 04-17-2009 12:40 PM In reply to
    Stan,
    It appears that this Toshiba TV uses 32 bit NEC protocol and I have sent you an e-mail with an XML file attached for your to test.
    Regards Keith....
