Hi all, I have a pleasant problem and need some advice since I can't make up my mind. I have recently sold my 7-40 MKIII and have two options as I see it :
- Buy the new 7-40 MKIV now and then switch to the new 7-55 when it is launched.
- Buy the 4-65 Plasma
What would you guys choose ??
Here is some of my questions/wonderings :
- I am a bit afraid that plasma is being replaced by LCD, LED etc. Noticed for example that Pioneer will stop making plasmas at the end of the year. What do you think ?
- Have anyone seen the 4-65 ? How is the picture compared to the 7-40 MKIII ?
- The new 7-55 will be LED. What do you think about LED ? Has anyone seen a LED-screen ? How is LED compared to plasma or LCD ?
- Is it anything else regarding these two models that I should think about ?
- What kind of plasma screen exactly is it in the 4-65 ? Noticed that the contrast ratio according to B&O is only 3000:1, but I heard from a dealer that B&O doesn't measure contrast the same way as other brands. Is this correct ?
Many questions and I am very thankful for all comments and opinions.
Best regards
Halid
