Latest post 05-22-2009 3:29 PM by BegBeo. 5 replies.
Page 1 of 1 (6 items)
  • 05-22-2009 4:35 AM
    • BegBeo
    • Not Ranked
    • Joined on 04-23-2008
    • Stockholm - Sweden
    • Posts 60
    • Gold Member
    Beolab Penta 2 No Stand by - Need help
    Hey, guys, have a Beolab Penta 2
    No stand-by - Fuses located in the bottom part is OK
    Does anyone have knowledge which mistakes are behind this error.
  • 05-22-2009 4:57 AM In reply to
    Re: Beolab Penta 2 Going from red to green but no sound - Need help
    how is the Penta connected to the amp? PowerLink or Cinch or Speakerlink?
    Could be a defekt Powerlink cable. Or wrong source selected...powerlink used, but line selected.
  • 05-22-2009 5:06 AM In reply to
    • BegBeo
    • Not Ranked
    • Posts 60
    • Gold Member
    I am very sorry I wrote wrong, I have no stand-by, even if the fuse is ok.
  • 05-22-2009 5:12 AM In reply to
    No standby LED?
    Then either the fuses are defect, there are 2 of them... 1x for the standby transformer and 1x for the power amp.
    Check with an ohmmeter wether there is some resistance on the power cord, there should be something around 300 Ohms. If there is a open loop, then the fuse or the standby transformer is gone...
  • 05-22-2009 5:18 AM In reply to
    • BegBeo
    • Not Ranked
    • Posts 60
    • Gold Member
    Thank you for your prompt response will look at it today and hear from me again how it was.
    regards
    Jan
  • 05-22-2009 3:29 PM In reply to
    • BegBeo
    • Not Ranked
    • Posts 60
    • Gold Member
    Hello again, Beolab Penta som are OK = 300 Ohms and the Beolab Penta with error had = 275 Ohms.
    What do you think?
    regards
    Jan
